Cavitation Number
An introduction and definition of the Cavitation Number.
The Cavitation Number or Cavitation Parameter is a "special edition" of the dimensionless Euler Number.
The Cavitation Number is useful when analyzing fluid flow dynamics problems where cavitation may occur.
The Cavitation Number can be expressed as
σ = (pr - pv) / (1/2 ρ v2)                              (1)
σ = Cavitation number
pr = reference pressure (Pa)
pv = vapor pressure of the fluid (Pa)
ρ = density of the fluid (kg/m3)
v = velocity of fluid (m/s)
To prevent cavitation
  • avoid low pressure - pressurize supply tanks if necessary
  • reduce fluid temperature
  • use larger suction pipe diameters - reduce minor losses
  • use cavitation resistant materials or coatings
  • small amounts of air supplied to the suction system may reduce the amount of cavitation damage
  • keep available NPSH well above required NPSH.
