Carbon Monoxide Gas - CO - Specific Heat vs. Temperature
Carbon Monoxide Gas - CO - specific heat of at temperatures ranging 175 - 6000 K.
Carbon monoxide, CO, is flammable and very hazardous since it is very toxic and odorless. Carbon monoxide can be produced from incomplete combustion due to lack of oxygen.
Carbon monoxide interferes with the distribution of oxygen in the blood to the rest of the body. Depending on the amount inhaled, this gas can impede coordination, worsen cardiovascular conditions, and produce fatigue, headache, weakness, confusion, disorientation, nausea, and dizziness. High levels causes death.
Specific heat (C) is the amount of heat required to change the temperature of a mass unit of a substance by one degree.
  • Isobaric specific heat (Cp) is used for substances in a constant pressure (ΔP = 0) system.
  • I sochoric specific heat  (Cv) is used for substances in a constant-volume (= isovolumetric or isometric ) closed system.
The specific heat  - CP and CV - will vary with temperature. When calculating mass and volume flow of a substance in heated or cooled systems with high accuracy - the specific heat (= heat capacity) should be corrected according values in the table below.
Specific heat of Carbon Monoxide Gas - CO - at temperatures ranging 175 - 6000 K:
Temperature
- T -
(K)
Specific Heat
- cp -
(kJ/kgK)
175 1.039
200 1.039
225 1.039
250 1.039
275 1.040
300 1.040
325 1.041
350 1.043
375 1.045
400 1.048
450 1.054
500 1.064
550 1.075
600 1.087
650 1.100
700 1.113
750 1.126
800 1.139
850 1.151
900 1.163
950 1.174
1000 1.185
1050 1.194
1100 1.203
1150 1.212
1200 1.220
1250 1.227
1300 1.234
1350 1.240
1400 1.246
1500 1.257
1600 1.267
1700 1.275
1800 1.282
1900 1.288
2000 1.294
2100 1.299
2200 1.304
2300 1.308
2400 1.311
2500 1.315
2600 1.318
2700 1.321
2800 1.324
2900 1.326
3000 1.329
3500 1.339
4000 1.346
4500 1.353
5000 1.359
5500 1.365
6000 1.370
The values above apply to undissociated states. At high temperatures above 1500 K dissociation becomes appreciable and pressure is a significant variable.
See also Specific heat of Air - at Constant Pressure and Varying Temperature, Air - at Constant Temperature and Varying Pressure, Ammonia, Butane, Carbon dioxide, Ethane, Ethanol, Ethylene, Hydrogen, Methane, Methanol, Nitrogen, Oxygen, Propane and Water.
