BEP - the Best Efficiency Point of a Pump
BEP is where the pump is most efficient.
A practical pump will never be able to convert all its kinetic energy to pressure energy. Parts of the energy will always be internal or external lost.
Internal Losses
  • hydraulic loss - due to disk friction in the impeller, rapid change in flow directions and velocity changes throughout the pump
  • volumetric loss - due to internal re-circulation caused by wear in rings and bushes
External Losses
  • mechanical loss - due to friction in seals and bearings
BEP - Best Efficiency Point
Pump - BEP - Best Efficiency Point
The maximum efficiency for a pump is normally in its "design point" - also called
  • BEP - or the "Best Efficiency Point"
For pumps operating in all other positions - the efficiency will be less than in BEP.
