Air Compressors - Maximum Air Flow vs. Inlet Pipe Size
Inlet pipe size and maximum air flow.
The pressure loss through an air compressor inlet should be kept to a minimum to avoid noise problems. The diagram below indicates reasonable maximum flow through an inlet pipe.
air compressor maximum inlet pipe size diagram
  • 1 cfm = 0.47 l/s
  • 1 inch = 25.4 mm
